THE PEAVEY T-40 BASS ENTHUSIASTS FORUM A FORUM FOR PEAVEY T-40 BASS ENTHUSIASTS |
| Author | Message |
Posts: 643 Join date: 2007-11-27 Age: 46 Location: Home of the Choo Choo
 | Subject: Peavey bass setup sheet Sat Dec 01, 2007 3:06 pm | |
| Here's a link to the Peavey bass setup sheet over at the T-60 Forum.
http://www.peaveyt60.com/forum/forum_posts.asp?TID=2149&PN=1 _________________ Tony ITOC #05-00013
3 T-60s, T-63, mini T-60, T-15, Generation Standard, Impact 1, Mantis LT, Milestone, Nitro III, Patriot tremolo, Predator, Raptor, Razer, Reactor, 4 Rockmasters, Tracer, Bandit, Micro Bass, Musician 400, VSS 20, Vypyr 30 and Sanpera I.
|  | | T-40 Admin
Posts: 85 Join date: 2007-11-17
 | Subject: Re: Peavey bass setup sheet Tue Dec 04, 2007 8:12 pm | |
| Excellent Find! Thanks for that! |
|  | | Frank N. Peavey
 | Subject: Re: Peavey bass setup sheet Wed Dec 05, 2007 6:55 pm | |
| No problem at all. That's what we do, share all the info we can get our hands on. _________________ Tony ITOC #05-00013
|  | | Scottpro1969
Posts: 419 Join date: 2007-11-27 Age: 42 Location: Minot AFB, ND
 | Subject: Re: Peavey bass setup sheet Sun Jan 06, 2008 3:22 am | |
| That's a great find Tony, thanks.
In my experience, if the action on a bass is high people automatically tighten the truss rod because doing so lowers the strings. Which doesn't always take care of the problem.
The truss rod is made to correct an actual bow in the neck, although it will lower the strings that's not it's intended purpose. That is what the bridge saddles and the neck tilt adjustment are for. If a neck has never been properly set up, correction of a problem can be a combination of all three possible solutions.
Follow the owners manual, adjust the neck truss rod in small....maybe 1/4 turn increments and go from there. |
|  | | Frank N. Peavey
 | Subject: Re: Peavey bass setup sheet Sun Jan 06, 2008 1:47 pm | |
| Agreed Scott. Always use the neck tilt first, followed by bridge height adjustment. Adjust the truss rod as a last resort. _________________ Tony ITOC #05-00013
|  | | Scottpro1969
 | Subject: Re: Peavey bass setup sheet Sun Jan 06, 2008 3:54 pm | |
| Right Tony, unless the bow IS the problem.
The T-40 recently bought had a very noticeable bow in the neck (the truss rod had never been touched, it was at full relief). Holding the bass bottom with my foot and eying from the headstock down you could easily see the bow, it was that pronounced. So, I adjusted the truss rod slightly, gave it some time and adjusted more until the neck was good (a guitar neck HAS to have a slight bow otherwise the strings would buzz on every fret). Then, I had to adjust the height adjustment screw, then the saddles. Each instrument is unique, depending on how it was treated since these great guitars and basses were made at least 20+ years ago.
Everyone's personal setup is....well...personal. Some might need high action because their playing technique is aggressive. |
|  | | Frank N. Peavey
 | Subject: Re: Peavey bass setup sheet Sun Jan 06, 2008 5:52 pm | |
| Exactly Scott. I've been lucky so far. None of my pawn shop rescued T's have need a truss adjustment. _________________ Tony ITOC #05-00013
|  | | ajish4
Posts: 110 Join date: 2008-03-04 Age: 50 Location: Stuart, FL
 | Subject: Re: Peavey bass setup sheet Sun Sep 07, 2008 5:35 pm | |
| OK guys, go easy on me.
I have never adjusted a truss rod before, I've always just dropped it off at the luther and have done with it.
I have my first "rescue" and it looks bad. What tool do I use to adjust the truss rod and neck adjsutment?
I'm green here guys, so the BASICS are whats needed for this idiot to get this right!
Thanks in advance.
Tony |
|  | | Frank N. Peavey
 | Subject: Re: Peavey bass setup sheet Mon Sep 08, 2008 11:46 am | |
| Peavey sells a truss rod wrench or you can use a thin walled socket of the appropriate size. I still haven't done any truss rod adjustments so I don't know the size socket. I think someone has replied in another thread with the correct size. _________________ Tony ITOC #05-00013
|  | | brem
Posts: 40 Join date: 2008-08-04 Age: 37 Location: Quebec City, QC, Canada
 | Subject: Re: Peavey bass setup sheet Mon Sep 08, 2008 12:48 pm | |
| What does ITOC stands for? |
|  | | Scottpro1969
 | Subject: Re: Peavey bass setup sheet Mon Sep 08, 2008 8:21 pm | |
| International "T" Owners Club. Tony, the truss rod takes a 5/16" socket type. Good luck ordering an original from Peavey. StewMac has one that will work. Buy the one for recessed truss rods. Here you go: http://www.stewmac.com/shop/Tools/Special_tools_for:_Truss_rods/Pocket_Truss_Rod_Wrenches.html |
|  | | Scottpro1969
 | Subject: Re: Peavey bass setup sheet Mon Sep 08, 2008 8:23 pm | |
| Tony, what is exactly the problem? Is the neck bowed in or out? PM me if you need some help. I'm glad to do it.
Scott |
|  | | OzarkRifleman
Posts: 104 Join date: 2008-07-20 Age: 36 Location: Cassville, MO
 | Subject: Re: Peavey bass setup sheet Mon Sep 08, 2008 10:39 pm | |
| Scott's the man, he'll help you out. |
|  | | Scottpro1969
 | Subject: Re: Peavey bass setup sheet Tue Sep 09, 2008 2:40 am | |
| Hell no, I'm not the man...but thanks for the confidence Jeremy I just have had about 7 years experience with T-40s, and have learned from trial and "error" what works and doesn't. With the neck-tilt, it can be a little finicky trying to figure out what the bass needs...truss rod, saddle, or neck-tilt adjustments. I always stress turning the truss rod as the last resort. |
|  | | ajish4
 | Subject: Re: Peavey bass setup sheet Tue Sep 09, 2008 2:53 pm | |
| Thanks Scott! I just ordered the truss Rod tool from the link you posted, THANK YOU. Here is the bass I just received, take a look at the LAST photo....it looks bad, I have a spare Rosewood neck but it looks like this truss rod was NEVER TURNED! I can't see ANY threads, just the top of the nut, it is finger loose! http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=180281295141&ssPageName=STRK:MEWN:IT&ih=008 I didn't even think I was going to win! I placed a BS BID and forgot about it! I just sold off two RICS so at least the wife isn't going to kill me! ANY advice would be greatly appreciated! Funny how different these basses, I have another Maple T-40 that is about 1/2 the weight of this killer! I'll PM you when the wrench arrives, I've NEVER worked on a truss rod before! Thanks!  |
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
