 Noob Q's
ståle
PostSubject: Noob Q's   Sun Oct 07, 2012 2:11 pm
Hi all ! Just picked up a T-40 with serial number 00551807. Would that make it an 80 model ?
It apparently has some issues with the electrics. As far as I can figure, only the bridge pickup works. The neck pickup doesn't respond at all. The phaser switch is broken as well.
Are there parts available out there ? Cheers Smile
ståle
PostSubject: Re: Noob Q's   Sun Oct 07, 2012 11:14 pm
After reading the user manual, it looks like it's actually the bridge pickup that's out of order. I lifted it out last night, but couldn't see anything obvious under there. I'll get a set of micro allen keys today, so I can get the volume/tone controls off and get under there.
PostSubject: Re: Noob Q's   Tue Oct 09, 2012 6:31 am
I put a list together on the T-60 Mafia Forum of all the T-60 replacement part sources I am aware of. Some of the items are common to both tthe T-60 and T-40.
http://www.houstonmusicreview.com/phpBB3/viewtopic.php?f=3&t=52
ståle
PostSubject: Re: Noob Q's   Tue Oct 09, 2012 6:37 am
Thanks, Tony !
PostSubject: Re: Noob Q's   Sat Oct 13, 2012 10:43 pm
Hope it helps you.
Noob Q's
» Noob to Galaxy Cauldron
» Noob needs help please
» Noob here, my pots
» [Aides Fatalities et Astuces/Soluces] Mortal Kombat 9
» Battlin Boxers vs Ninja's
