Mr. Dreadful
Posts : 2 Join date : 2013-11-29 Age : 44 Location : Swindoom, Wiltshire, England
| Subject: T-40ing a Non-T-40 Fri Nov 29, 2013 10:24 am | |
| Hello!
(I originally put this in T-40 Discussion, but found that this forum was also still active so moved it here!)
Basically I have major GAS for a T-40, but lack the funds for one. BUT I do have a bass with two MM-style humbuckers (4-con), individual vol/tone for each pickup and plenty of space in the cavity for a wee phase switch.
So, what I come here to ask you fine people is your thoughts on taking the lid off and re-wiring as per the T-40 schematic so I get a wider range of sounds and if not actually have a T-40 at least be able to replicate the sound a bit.
Any thoughts? The pickups are generic Far Eastern things, so can't elaborate there unfortuntely. | |
Posts : 55 Join date : 2007-12-16 Age : 84 Location : Galveston, TX
| Subject: Re: T-40ing a Non-T-40 Fri Sep 16, 2016 11:38 am | |
| The rewiring you are requesting requires humbucking pickups with center-taps. The sound requires one coil of the pickup being gradually faded out to ground Chip | |
Mr. Dreadful
| Subject: Re: T-40ing a Non-T-40 Fri Sep 16, 2016 11:57 am | |
| Subject: Re: T-40ing a Non-T-40 | |
