 My neck on my t-40 buzzes and cant be fixed time to replace?
emericaSKATER22
PostSubject: My neck on my t-40 buzzes and cant be fixed time to replace?   Fri Feb 24, 2012 2:06 pm
Ive taken my bass twice to guitar center and the tech cant get rid of the buzz, would replacing my neck solve the problem? if so where can i get one? Thanks
PostSubject: Re: My neck on my t-40 buzzes and cant be fixed time to replace?   Fri Feb 24, 2012 4:00 pm
Try a different shop (not guitar center)
PostSubject: Re: My neck on my t-40 buzzes and cant be fixed time to replace?   Mon Feb 27, 2012 10:28 pm
Agreed.
And PM your email address to me and I'll get you a copy of the Peavey set up sheet so you can ensure the shop sets it up as Chip intended it to be.
MachinesUK
PostSubject: Re: My neck on my t-40 buzzes and cant be fixed time to replace?   Mon Apr 09, 2012 9:53 am
(My first post here)
I was having the same trouble with mine but isolated the buzz to the truss rod nut which was loose. I gave it a little tightening (hardly even 1/8 a turn) and the buzz has gone ! Give it a try.
View user profile http://www.basschat.co.uk
» Aspen Neck Warmer - crochet
» Spectrum ST neck
» Neck radius
» Antagonist: Nightmare Moon//Senshi: Sailor Luna
» Wisdom tooth extraction...the upsell...grrrrrr!!
