| Peavey Torsion Rod Wrench | |
+5Aladaube el duderino T-40 Frank N. Peavey pfo 9 posters |
pfo
Posts : 3 Join date : 2007-12-10
| Subject: Peavey Torsion Rod Wrench Fri Dec 14, 2007 12:50 am | |
| Reading the manual, it says that the truss rod adjustments should be made with a Peavey Torsion Rod Wrench -- is this true? Will a regular Allen Key work or do I need to buy a special tool?
Thanks! | |
| Subject: Re: Peavey Torsion Rod Wrench Fri Dec 14, 2007 5:53 am | |
| You'll need a thin wall socket or the Peavey tool to make the adjustments. I don't have the size written down though. I'm sure someone else will stumble in with the correct size. | |
T-40 Admin
Posts : 85 Join date : 2007-11-17
| Subject: Re: Peavey Torsion Rod Wrench Fri Dec 14, 2007 12:55 pm | |
| A gibson guitar tool will work too. These are SUPER cheap and easy to find. Music store always forget to give these to their customers, especially guitar center! They have TONS of them. Just ask for one! | |
Posts : 106 Join date : 2007-11-17
| Subject: Re: Peavey Torsion Rod Wrench Fri Dec 14, 2007 11:44 pm | |
| - T-40 wrote:
- A gibson guitar tool will work too. These are SUPER cheap and easy to find. Music store always forget to give these to their customers, especially guitar center! They have TONS of them. Just ask for one!
I have an actual wrench that I got for $6 from Peavey, but if I ever lose it, that's good to know. | |
Aladaube
Posts : 33 Join date : 2007-12-08
| Subject: Re: Peavey Torsion Rod Wrench Sat Dec 15, 2007 2:59 am | |
| I've seen the socket size given variously as 5/16", 11/32" and 8mm. | |
pfo
| Subject: Re: Peavey Torsion Rod Wrench Sun Dec 16, 2007 3:21 am | |
| Thanks guys, so a Gibson tool should work huh....well, I'm off to Guitar Center to see if I can't pick up one of their spares. Dude (I'm into the whole brevity thing ), did you call Peavey to order that tool? | |
ropingk
Posts : 29 Join date : 2007-11-26
| Subject: Re: Peavey Torsion Rod Wrench Sun Dec 16, 2007 10:02 am | |
| Yes you can call the parts department and just order a wernch HOWEVER I think thjey are now like $15 and the wqit time is kinda long | |
| Subject: Re: Peavey Torsion Rod Wrench Mon Dec 17, 2007 9:58 pm | |
| - ropingk wrote:
- Yes you can call the parts department and just order a wernch HOWEVER I think thjey are now like $15 and the wqit time is kinda long
Possibly, but I only ordered mine about a year and a half ago and it came within a week and only cost $6. but then again, the popularity has been steadily climbing since then. | |
Alvaro Martín Gómez A.
Posts : 16 Join date : 2007-12-28 Age : 57 Location : Bucaramanga, Colombia, South America
| Subject: Re: Peavey Torsion Rod Wrench Sat Dec 29, 2007 5:41 pm | |
| Well, I've just ordered a pocket 5/16" Gibson wrench from Stewmac.com. My T-40's neck is perfectly straight and I want it to have a bit of relief, but the wrench I have for this has a very long head and it doesn't fit the truss rod cavity's top end. I hope this one will work. | |
| Subject: Re: Peavey Torsion Rod Wrench Wed Jan 02, 2008 1:21 pm | |
| - Alvaro Martín Gómez A. wrote:
- Well, I've just ordered a pocket 5/16" Gibson wrench from Stewmac.com. My T-40's neck is perfectly straight and I want it to have a bit of relief, but the wrench I have for this has a very long head and it doesn't fit the truss rod cavity's top end. I hope this one will work.
Well, it seems that I made a good decision! - Quote :
Date: Wednesday, January 02, 2008 02:08 PM
It's a 1981 model and the wrench is a 5/16" socket type which is available at http://www.stewmac.com/shop/Truss_rods/Wrenches,_hex_keys/Pocket_Truss_Rod_Wrenches.html
Thank you, Anthony | |
wanderlusterer
Posts : 14 Join date : 2007-12-07
| Subject: Re: Peavey Torsion Rod Wrench Sat Jan 12, 2008 6:24 am | |
| I called Peavey last week. Since in the past month, I've bought 2 T-40's!!!!!
They don't carry parts for them any more and suggested that I call Allparts.com and ask them. I did and they sent a 5/16 tool for $6.
FYI. | |
countshock
Posts : 26 Join date : 2008-01-04
| Subject: Re: Peavey Torsion Rod Wrench Sat Jan 12, 2008 9:50 pm | |
| the size is 5/16 and you can get them from stewmac.com | |
| Subject: Re: Peavey Torsion Rod Wrench | |
