 500 kOhm pots on a T-40
Greg L.
PostSubject: 500 kOhm pots on a T-40   Sun Feb 14, 2010 1:04 am
Hey,
Sometimes I think that the sound I get from my T-40 bass isn't open enough. Has someone ever tried to put 500k pots on a T-40, instead of the 250k ?
I plan to modify my bass with 2 500k push-pull pots to split the pickups, instead of the original system.
View user profile http://fastmotion.fr
rwn
PostSubject: Tried 500k pots, it was somewhat awkward.   Fri Aug 20, 2010 7:29 am
I tried to install a standard 500k pot, but the control level in each pick-up lacked fine adjustment: They had a tendency to either be all the way, or none at all when it came to gain. Perhaps the push/pull pots would work better. This was also when I was seventeen, so some of the issue might have been my rather weak soldering skills.
PostSubject: 500kOhm pots on a T-40   Fri Aug 20, 2010 9:33 pm
I would think it obvious that such was tried when we were designing the instrument. The extra resistance makes the volume control happen about when the pot reaches its halfway (resistance, not knob numbers), point. The extra resistance also helps trim out the nice treble overtones.
A 500 kOhms pot at the tone position really knocks the high overtones and the T-40 doesn't need any more bottom.
I state this without any subjectivity, as R. T. Lowe did the fine-tuning of the circuitry, along with some fine help from Charley Gressett.
PostSubject: Re: 500 kOhm pots on a T-40
» Which Deoxit for pots?
» are modern pots going in the right direction? my thoughts and hopefully yours
» Carved stone pots?
» Creativity in Bonsai Pots
» Cleaning pots
THE PEAVEY T-40 BASS ENTHUSIASTS FORUM :: T-40 DISCUSSION :: WEIRD OR MODDED T-40's-
