 Trussrod problem
Sanemancured
PostSubject: Trussrod problem   Fri Nov 21, 2008 1:48 am
Greetings all. I recently purchased a T40 in fair to good condition for a bargain price and was guided here from the Finnbass bass forum.
I'm from Kendal in the UK.
I've just received a trussrod spanner from StewMac and as there is slightly more relief in the neck than I would like/is desireable I gently tried to tighten the rod. I noticed the nut has a lot of threads showing implying that it's quite loose.
It felt good but the nut isn't moving down the threaded rod and I suspect that the whole trussrod is turning inside the neck. The neck relief is unchanged.
Any ideas or tips on a way ahead? The bass is playable but not very enjoyable to play as it is.
I've had an idea and it involves superglue affraid
Peter
Sanemancured
PostSubject: Re: Trussrod problem   Fri Nov 21, 2008 12:29 pm
Just an update to say problem sorted. The trussrod wasn't spinning in the neck it was just slackened off a very very long way.
All set up nicely now.
Trussrod problem
» possible 4l60e problem?
» I need some help with a Nerf problem..
» power transformer problem - help?
» Don Juan Rehearsal...What's really the problem here?
» Please help me diagnose a running condition problem.
