| serial numbers | |
+66JohnGroenen RumbleBass Borisuzi minervadreaming GB Johnny Crab TrebleHead082 Shabbs Chris K blaine63 metalchild92797 candybuck2006 CW deadpool 58mark don_frouse tapman sienjake timonvh derelict78 eqworks DFA 79 marijn c RichardH stinky634 dannymacc Santi pbrdrnkr NGPeavey Eric Chris In NOLA cdougyfresh gastric homero Jeffrey71 todd Bigbzbass nateh415 Squidward247 NOZHX mtseiler davidgsanpablo OzarkRifleman Tamhellspawn lingo coleus aaronrushmore Bett Barking Pumpkin thepull Java kevdel countshock wanderlusterer daniel Elmore Pipou jtre Aladaube mechazawa geekboy_rick el duderino Scottpro1969 freeridstylee lugrug Frank N. Peavey 70 posters |
blaine63
Posts : 9 Join date : 2010-12-20 Location : SoCal
| Subject: Re: serial numbers Sat Jul 14, 2012 8:40 am | |
| Subject: Re: serial numbers Mon Jul 16, 2012 5:39 am | |
| - blaine63 wrote:
- Hey, Frank, three more for the list.
T-15 (recent Ebay purchase): 01088152 (sticker on the back of the headstock is from a music store in McAlester, Ok but I can't make out the name of the store).
T-30 (another recent Ebay purchase): 0112416.
T-40 (I'm the original owner from 1980!): 00395954.
The T-30 serial number only has 7 numbers. Should be 8. | |
blaine63
| Subject: Re: serial numbers Mon Jul 16, 2012 9:52 am | |
| My mistake. T-30: 01102416 | |
| Subject: Re: serial numbers Mon Jul 16, 2012 9:17 pm | |
| No problem at all. My laptop keyboard screws up numbers all the time. | |
blaine63
| Subject: Re: serial numbers Tue Jul 31, 2012 12:23 am | |
| Got another T-15 for you frank: 01609892 | |
| Subject: Re: serial numbers Tue Jul 31, 2012 7:25 am | |
| Thanks, got it added.
You've been on quite the acquisiton spree lately. | |
Chris K
Posts : 4 Join date : 2012-09-03
| Subject: Feel free to add mine to the database, too Mon Sep 03, 2012 10:15 pm | |
| Hi Frank. I have a 1978 T-40 serial number 8M273400. I am the original owner. This is the one I just finished restoring. | |
blaine63
| Subject: Re: serial numbers Tue Sep 04, 2012 10:02 pm | |
| Frank (or anyone else):
What's the preferred method for stringing a T-15 or T-30 bridge? Through the bottom or through the back? I've seen both and have done both.
| Subject: Re: serial numbers Wed Sep 05, 2012 9:39 pm | |
| - Chris K wrote:
- Hi Frank. I have a 1978 T-40 serial number 8M273400. I am the original owner. This is the one I just finished restoring.
Thanks Chris. I'll update my spreadsheet. And congrats on the rebuild. I was wondering about the pin stripe on your headstock. Does it surround the truss rod cover or run behind it?
Last edited by Frank N. Peavey on Wed Sep 05, 2012 9:47 pm; edited 1 time in total | |
| Subject: Re: serial numbers Wed Sep 05, 2012 9:42 pm | |
| - blaine63 wrote:
- Frank (or anyone else):
I've only seen one type bridge on the T-15/T-30. You can only load the string in the channel behind the saddle piece there isn't a through the body option on those guitars. The T-60/T-40 are loaded that way. | |
blaine63
| Subject: Re: serial numbers Fri Sep 07, 2012 7:51 pm | |
| Sorry. I wasn't clear. On all of the T-13/T-30 bridges I have there's the channel you describe on the base plate of the bridge and on the back wall (as it were) there are six holes that you can also string through. I've seen it strung through both ways. I didn't mean string through the body like a telecaster.
Bad choice of words on my part. | |
| Subject: Re: serial numbers Mon Sep 10, 2012 12:20 pm | |
| Okay, I see what you mean now.
All that I have played were strung through the base. I don't recall having seen on with the strings passed through the rear of the bridge. | |
Shabbs
Posts : 1 Join date : 2012-11-25
| Subject: Re: serial numbers Sun Nov 25, 2012 12:46 pm | |
| Hi Frank Just joined and thought I'd post my T-40 serial, I noticed one very close to mine earlier, mines I believe is a 1979 serial 00396236, purchased second hand in Glasgow in 1987. Cheers. Ian. | |
| Subject: Re: serial numbers Sun Nov 25, 2012 10:12 pm | |
| Thanks Shabbs, got your added to the database. Looks like a 1979 to me as well.
The closest I've got in the database to yours is 00396265. I did find a 00396326. Same numbers in different sequence. | |
TrebleHead082
Posts : 1 Join date : 2012-12-05 Age : 29 Location : Way out West
| Subject: Re: serial numbers Thu Dec 06, 2012 7:03 am | |
| Hey Frank! Im new here, i just aqquired a '82 T-40. No problem besides some dolt putting in a 2-way pickup selector switch.
Anywho, my serial number is
01116039
| Subject: Re: serial numbers Fri Dec 07, 2012 5:29 pm | |
| Thanks, I'll get it added to the database. | |
Johnny Crab
Posts : 1 Join date : 2012-12-07
| Subject: Re: serial numbers Fri Dec 07, 2012 10:19 pm | |
| Just picked up a very tired T-40 today. It has just been cleaned, inspected, and new strings put on. What's needed(we do our own work): 1) Case needs relined 2) 2 of 4 springs missing on the bridge saddles, 1 screw is not OEM(head is too large) 3) Crack on the pickguard near the bridge 4) Previous owner(s) removed the phase switch and replaced it with a 1/4" jack. 5) The other switch now has a poorly-fit slide switch for pickup selection(Frt, Rr, both) 6) Where the A string crosses the 3rd fret, there is 1/4" deep burn hole(looks like a soldering iron wound) 7) No truss rod cover
If it plays good(seems to already) and sounds good, it's a keeper. For now it's going to sit overnight and let the neck adjust(if it even moves at all) to the new strings(a bit lighter gauge, my preference for all basses here).
Serial number is 00378117.
This is my 1st T-40 but I remember seeing and hearing Louisiana's Leroux(Leon Medica) using one on albums and live at Ol' Man Rivers in New Orleans a zillion years ago. Never had $$$ + access to one until now. | |
| Subject: Re: serial numbers Sun Dec 09, 2012 10:53 pm | |
| I just added yours to the database.
I have seen plenty of phase switches replaced with three-ways but this is the first time I've seen one replaced with a 1/4" jack. Did the previous owner replace the existing output jack or make it stereo?
Can't say I've seen a soldering scar on a fingerboard either. | |
GB
| Subject: Re: serial numbers Wed Dec 19, 2012 7:51 am | |
| Here's another one for you, in the Netherlands, previous owner thought it was a '79.
Different switches then i've seen on T-40 pictures, probably replaced.
Serial: 00377066 | |
| Subject: Re: serial numbers Thu Dec 20, 2012 4:25 pm | |
| Thanks, got it added to the database. Looks like a '79 to me. | |
minervadreaming
Posts : 2 Join date : 2012-12-28
| Subject: Re: serial numbers Fri Dec 28, 2012 11:21 pm | |
| Just picked up a T-40, here's the serial: 01221806
All stock except for the phase switch, which has been replaced with a 3-way toggle. Not sure why or what the difference is, I think I'll have to open it up to find out. | |
| Subject: Re: serial numbers Sat Dec 29, 2012 4:07 am | |
| Thanks, got yours added to the database. | |
Borisuzi
Posts : 4 Join date : 2013-02-13
| Subject: Here is my serial number Wed Feb 20, 2013 4:45 pm | |
| We have just inherited this T40 in mint condition. We don't think that it has ever been played. It still has the plastic on the scratch plate, it is in a rectangle hard case with a coppery velvet lining. 8M273020.
I am trying to put up a photo but I can't get them to upload? | |
| Subject: Re: serial numbers Thu Feb 21, 2013 1:35 am | |
| Congrats! You've got a very early T-40 from 1978. And you still got the pickguard cling, don't see a whole lot of those left these days.
RumbleBass
Posts : 1 Join date : 2013-02-22 Age : 42 Location : FRANCE
| Subject: Re: serial numbers Fri Feb 22, 2013 7:54 am | |
| Hi all ! You can add my serial to your database. 00681389. Appears to be a 81 ? Natural finish, Maple fingerboard, Toasters, 5 pieces body, patent pending on headstock. Dont know her history, bought her at a guy who bought her 2 years ago at a guy who bought her at guy, maybe that during more than 30 years...I'm from France, paid 500 euros for it with original case. Hard to find in France/Europe at a fair price and in good health, from good years. Seen one offer recently at 650 euros for a 1982 with blades, no case. Mine seems to have been quite played, some scratches, dings, but good fretwear, electronics ok, no broken or missing parts. There's marks of a removed "BLITZ" sticker from a previous owner on body, does it tells something to anyone here ? These basses are awesome, played on lot of stuff like warwick, high-end Yamaha, Musicman, g&l, and definitely this girl has lot of mojo ! I kept a g&l asat only with her. Playin her in a Marshall DBS7400 with 4x12+1x15, Mad Professor BlueBerry, DGCF, C dropin sometimes, D'Addario Prosteels, LOVE ! If only I could have met her earlier in my bassist life. I'll never sell her, really thinking of starting a collection, I would be happy to offer her some sisters of others colors and ages. At least for now, I've this one, from my birth year ! [img][/img] [img][/img] [img][/img] [img][/img] [img][/img] | |
| Subject: Re: serial numbers | |
| serial numbers | |
