 T-40ing a Non-T-40
Mr. Dreadful
PostSubject: T-40ing a Non-T-40   Fri Nov 29, 2013 10:24 am
Hello!
(I originally put this in T-40 Discussion, but found that this forum was also still active so moved it here!)
Basically I have major GAS for a T-40, but lack the funds for one. BUT I do have a bass with two MM-style humbuckers (4-con), individual vol/tone for each pickup and plenty of space in the cavity for a wee phase switch.
So, what I come here to ask you fine people is your thoughts on taking the lid off and re-wiring as per the T-40 schematic so I get a wider range of sounds and if not actually have a T-40 at least be able to replicate the sound a bit.
Any thoughts? The pickups are generic Far Eastern things, so can't elaborate there unfortuntely.
View user profile http://atomictangerinemusic.blogspot.com
PostSubject: Re: T-40ing a Non-T-40   Fri Sep 16, 2016 11:38 am
The rewiring you are requesting requires humbucking pickups with center-taps. The sound requires one coil of the pickup being gradually faded out to ground
Mr. Dreadful
PostSubject: Re: T-40ing a Non-T-40   Fri Sep 16, 2016 11:57 am
Dude, this thread is nearly three years old.
As I had no replies I went and did the thing anyway and it worked a treat. Smile
http://atomictangerinemusic.blogspot.co.uk/2014/03/carlsbro-pa60-blues-and-retrovibe-rvt-40.html
T-40ing a Non-T-40
