THE PEAVEY T-40 BASS ENTHUSIASTS FORUM A FORUM FOR PEAVEY T-40 BASS ENTHUSIASTS |
| | Author | Message |
king_biscuit
Posts: 2 Join date: 2008-01-26
 | Subject: Replacement phase switch Sat Jan 26, 2008 6:27 am | |
| What is a good replacement phase switch for the T-40. I know it is just an on/on DPDT switch, but does anybody know a source for a flat handle switch similar to the original? Thanks. btw, I'm new here and this forum is a cool idea. I've had my T-40 since 1983 (its an early 79 model). |
|  | | Frank N. Peavey
Posts: 643 Join date: 2007-11-27 Age: 46 Location: Home of the Choo Choo
 | Subject: Re: Replacement phase switch Sat Jan 26, 2008 12:51 pm | |
| Mike Frederick wrote an article about replacement switch sources over at the T-60 Forum.
Phase switch: Allparts EP 0180-010 On-On Mini Switch, SPDT or Radio Shack (DPDT Flatted Metal Level Toggle Switch #275-636).
http://www.peaveyt60.com/switch.htm _________________ Tony ITOC #05-00013
3 T-60s, T-63, mini T-60, T-15, Generation Standard, Impact 1, Mantis LT, Milestone, Nitro III, Patriot tremolo, Predator, Raptor, Razer, Reactor, 4 Rockmasters, Tracer, Bandit, Micro Bass, Musician 400, VSS 20, Vypyr 30 and Sanpera I.
|  | | king_biscuit
 | Subject: Re: Replacement phase switch Sat Jan 26, 2008 3:58 pm | |
| Thanks Tony. I am going by Radio Shack today to see if they have it. |
|  | | Scottpro1969
Posts: 419 Join date: 2007-11-27 Age: 42 Location: Minot AFB, ND
 | Subject: Re: Replacement phase switch Sat Jan 26, 2008 11:02 pm | |
| Tony is da man. Forgot to congratulate you on your USAF retirement (very belated). I had talked to you on the T-60 forum about maybe attending your ceremony but it didn't work out. Gosh, had I gone in the AF when I wanted to I could retire this year too. Instead I have 13 more years to go.  |
|  | | Frank N. Peavey
 | Subject: Re: Replacement phase switch Sun Jan 27, 2008 2:15 pm | |
| Thanks KB, just passing along the info we've compiled to make life easier on other T-owners.
No sweat Scott. Hang in there and you'll get your blue ID card soon enough. I've got some ceremony pics on my My Space, PM me if you want the address to check them out. _________________ Tony ITOC #05-00013
|  | | poomwah
Posts: 3 Join date: 2008-03-16
 | Subject: Re: Replacement phase switch Sun Mar 16, 2008 5:14 pm | |
| according to radioshack, the 275-636 mounts in a 1/4 inch hole. isnt that too big ? |
|  | | Frank N. Peavey
 | Subject: Re: Replacement phase switch Mon Mar 17, 2008 7:31 am | |
| I don't have any T's taken apart at the moment, so I can't verify the exact sizes. But remember that the early T's came with the small flat switches while the later T's came with the larger bat switches. The mounting holes are different sizes. _________________ Tony ITOC #05-00013
|  | | kevdel
Posts: 17 Join date: 2008-01-29 Age: 45 Location: Maryland
 | Subject: Re: Replacement phase switch Tue Mar 18, 2008 12:01 pm | |
| PT43, do you have a part number and a source for the two bat switches? I haven't been able to find any information on them. Thank-you. |
|  | | Frank N. Peavey
 | Subject: Re: Replacement phase switch Wed Mar 19, 2008 10:43 am | |
| I'm still trying to find those myself. I was wanting to use those in my Frank N. Peavey and T-63 projects but may have to go with the small flat switches. _________________ Tony ITOC #05-00013
|  | | cebreez84
Posts: 1 Join date: 2009-08-20
 | Subject: Re: Replacement phase switch Thu Apr 15, 2010 7:20 pm | |
| Wish I had found this thread sooner but in case anyone else finds it like I did. The paddle switches in question on the T-60, T-40. The pickup switch is a DPDT or double pole double throw because it needs three positions. Now operate your phase switch. It is more like an on off switch except that they needed to be able to reverse the coils and put the pickups out of phase. This requires a DPST or double pole single throw. Radio shack sells an exact replacement for the DPDT pickup switch but for some unknown reason nobody wants to supply the DPST for the phase switch as I have had a terrible time finding one. The same has been true for the tone pots, I cannot find anyone who sells the split pots which from what I understand was a Peavey patented part. |
|  | | Barrowford Bluesman
Posts: 3 Join date: 2010-05-20 Age: 54 Location: Kingdom of Pendle, England
 | Subject: Re: Replacement phase switch Fri Jun 25, 2010 10:47 am | |
| Try this:
http://www.axesrus.com/axecart.htm
I'm having some repairs done on my T40 and we got our switches here.
Ian
Similar topics |  |
| | Permissions in this forum: | You cannot reply to topics in this forum
