Share
 pickups
countshock
pickups Empty
PostSubject: update   pickups I_icon_minitimeMon Feb 11, 2008 3:02 pm
Just wired in the new switch this weekend, while I was at it, re-adjusted neck, new pickup surrounds, new screws and a few new bridge saddles. To my surprise, everything works great now! Thanks for the help guys!
jtre
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeSat Feb 02, 2008 8:12 pm
don't know what he wants for them, & i hope the link works. just rediscovered a tech who has a site about repair & mods he does. someone should slap one or two of these in:
http://www.timeelect.com/4$ale/4$ale-TE42.htm
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeThu Jan 31, 2008 5:46 pm
countshock wrote:
Hey guys, I just tested the switch, it's bad. Got a new one on the way!
Good deal. At least now you don't have to worry about finding another pickup.
countshock
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeThu Jan 31, 2008 7:59 am
freeridstylee
freeridstylee
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeTue Jan 29, 2008 8:28 pm
Yea if it works out of phase, I can't see any reason it wouldn't work in phase.
1+ bad switch
countshock
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeTue Jan 29, 2008 6:35 am
Duderino, that's a good idea, I'll have to give it a shot, thanks.
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeSun Jan 27, 2008 4:23 pm
countshock wrote:
Well, all the wiring seems to be intact, and I cleaned all the pots with electrical cleaner, still no luck. The pickup still only works out of phase. So, if anyone out there has a spare pickup or a source for one, let me know. Thanks!
I could be wrong, but if it works out of phase, the phase switch might be broken internally. You could always try bypassing it to see if it works without the phase switch.
countshock
pickups Empty
PostSubject: T-40 pickup   pickups I_icon_minitimeSat Jan 26, 2008 5:13 pm
countshock
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeFri Jan 25, 2008 6:33 am
Thanks for the info, I have to check the wiring on my bridge pickup, as it only seems to be working out of phase. Hopefully I can get it working. So I'm gonna try that first.
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeThu Jan 24, 2008 7:51 pm
Also, I would imagine that a Dimarzio X2N-B might work well as a replacement, as it is a bladed humbucker as well. They don't list it on their site, but I believe that it can still be special ordered.
jtre
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeTue Jan 22, 2008 11:15 am
it is smaller than a stock T-40, wouldn't use at the bridge position of a T-40, the pole pieces are too narrowly spaced, fine at the neck. the plastic surround i had came off in bits, so it needs that & the spring screws for height adjustment. this is a creme colored humbucker that was a replacement for a Gibson, the surround is an item you can get anywhere, a Gibson humbucker surround. DiMarzio discontinued it, they were once pretty common, Schaller makes a Starbucker now that looks just like it, creme colored, one height adjustment screw per side.
countshock
pickups Empty
PostSubject: pickup   pickups I_icon_minitimeTue Jan 22, 2008 10:22 am
Is that a good fit? Or does it require some mods?
jtre
pickups Empty
PostSubject: Re: pickups   pickups I_icon_minitimeTue Jan 22, 2008 9:32 am
can't help you with a genuine T-40 p/u, but if you don't have anything, you can have the DiMarzio model G that i had in the neck position of a T-40 for many moons, lemme know
countshock
pickups Empty
PostSubject: pickups   pickups I_icon_minitimeFri Jan 18, 2008 1:00 pm
Hi guys, I just bought a t-45 to cannibalize, but it's too nice. Hence, I am still in the market for T-40 pickups. Anyone out there have an extra?
pickups Empty
pickups
» WTB: GMC/Chevy pickup, $5000
» Wanna run this by you guys
» MMK pickups
» Coil-splitting/Magnaflux replacement pickups?
THE PEAVEY T-40 BASS ENTHUSIASTS FORUM :: T-40 DISCUSSION :: TRADING POST-
